Mercedes Benz w211 problem
13K views 5 replies 4 participants last post by  fatjet
Hello guys ... So i recently bought a used MB w211 , E270... Yesterday while driving , the engine sign came up and when i was trying to go almost full throttle , the car didnt speed up at all .... it was going as fast as when u only touch the gas pedal ...When i stop ,turn off the car then turn on again and then start driving there is no engine sing on the monitor ... only when i try to go faster ....Also the error seems to be p2047
Does anybody know whats causing the problem ?
From the sprinter forums that use the exact same engine.
P2047 = Rail pressure monitoring via volume control valve .: The maximum rail pressure was exceeded.
This usually is a low pressure condition in the rail... (The code is decieving) Start all fuel testing with checking the low pressure side first.
I have had this code on more Sprinters than I can count and it (most of the times) is a filter
#5 ·
How many miles on it?
Where are you located?
What is it's previous history?
