M119 Engine - What Oil Do You Use?
  • AmsOil
    Votes: 0 0%
  • Castrol
    Votes: 6 14%
  • Havoline
    Votes: 0 0%
  • Liqui Moly
    Votes: 9 20%
  • Lucas Oil
    Votes: 0 0%
  • Mobil 1
    Votes: 19 43%
  • Motul
    Votes: 3 6.8%
  • Pennzoil
    Votes: 3 6.8%
  • Quaker State
    Votes: 0 0%
  • Royal Purple
    Votes: 2 4.5%
  • Shell
    Votes: 1 2.3%
  • SynLube
    Votes: 0 0%
  • Tota
    Votes: 0 0%
  • Valvoline
    Votes: 5 11%
M119 Engine Oil - What Do You Use?
1 reading
22K views 14 replies 11 participants last post by  Roscoe_Aus
OK Benz-friends: yet another oil thread, although hopefully a rather focused one.
What I am trying to achieve with this one is fairly simple: I want to get a feel for who is running what oil in their M119 engines. I have purposely ignored dino oils and focused entirely on full synthetic oils.
Please select the brand that you are using and post the specifics – type, weight and so on – and a few words about your experience with it.
For the record: Yes, I know that MB recommends Mobil 1, that is not the question.
I will kick this off: I have been using Liqui-Moly 5w-40 but on my last oil change I went to Mobil 1 5w-30. I had the Liqui-Moly analyzed by BlackStone-Labs and it came back with good results, however Mobil 1 was much more readily available so I went with that.
Both oils seem very similar in use: on a hot day in traffic both gave 1 bar at idle and 3 bars at > 1,000rpm.
#5 · (Edited)
This car has always had mobil 1.
When I got it three years ago I was using 10?40. Now I'm buying qt cases at the dealer that are officially Mercedes Benz oil but I was told they're really mobil 1. It's 5-40.
I think you want to make sure it passes Mercedes 229 specification. Not all mobile 1 formulations are the same.
Edit: I would add my experience with Mobil 1 over 40 years. It's pretty amazing stuff. Had a car run out of coolant - engine got hot enough to crack both the cast iron block and aluminum cylinder head, and we still used the cams and crank into the new engine. Of course that protection is more academic when your engine is ruined anyway.
I have noticed with our high heat in summer - 40C or over 100F - it will idle at .5 bar. Or less.
Here's a picture of the valve train when I had to replace the oiler tubes.
#7 ·
I voted Valvoline, but I didn't read that you were only looking at synthetics. I am using Valvoline VR-1 Racing Oil 10w-30 in the dino version and absolutely love it. Just by using the gauges as a barometer the car runs slightly cooler with it but holds great pressure. They also have a full synthetic version. I recommend you look into it. I buy mine at the local Napa Auto Parts.
#9 ·
For me the choice is mainly about maintaining a 'good' oil pressure at hot idle when ambient temps are up around 30 to 40deg C. (Summer driving hols in S France over Alps :grin). A gradual drop in the hot idle pressure would indicate to me that the viscosity modifiers (long chain polymers) in the oil are starting to break down.
I buy top end fully synthetics so I take the lubricating properties for granted, but I favour the higher zinc content formulations.
I experimented with several makes and weights within MBs spec and found that mid range Casfrol or Mobil 10w/40 5w/40 0w/40 synthetics hot idled at 1.5 to 2 bar when new, but thinned out quickly after a longish hot run and hot idled permanently thereafter at 1 to 1.5 bar. :(
For years now I have used race derived tri-ester fully synthetics. My favourite is Millers 10w/60 tri-ester, then Mobil 10w/60. Hot idle never drops below 2 bar and I do mean never. :)
Happy Days!
#10 ·
Engine oil
Hi, in response to the question of which type or brand to use I had a conversation with my friend who is a race car engine builder on the side. He is also a machinist ( he is fabricating my head rest gears). Over a couple of beers we started talking about this same topic. His wife owns MBs and he does the work on them. He asked what kind of oil I used and I said synthetic. He told me that a 1991 motor ( even a MB one) was not designed for synthetic oil. The tolerances in a motor of that design would not be as effective using it. He believes at high temp the oil would be thinned out and not providing proper lubrication. H noted that is his opinion and one that of course can be challenged. He used the new Dodge Hellcat motor as a example of a motor made to almost unbelievable tolerances to get crazy hosepower and made for only synthetic oil. As in MB the oil pan is large to make sure that under hard use you do not have your oil pick up starved and also to assist in cooling. Then our conversation switched to suspension and I got completely lost so I drank lots of beer and just listened.
#12 ·
One thing that has amazed me (in a pleasant way) about my engine is how little oil it consumes. When you buy a (then) 17 year old car that is a cause for concern. And most of that seems to be leakage somewhere on the right side (I got ample opportunity to see it while wrestling with the motor mounts a month ago).
I doubt that I use a quart in 7500 miles. Car has 165,000 miles. According to a dealer tech who has gone on our club drives, this is not unusual for the M119.
The "Mercedes-Benz" oil someone else showed (I use it now too) is Mobil 1 5w-40, according to my parts friends. That must be a viscosity strictly for Mercedes as I have not seen it in the US in a Mobil 1 container.
