Have any of yall done or seen an LS swap in an W210? I'm thinking of starting an ls swap on my 2000 E320 and wanted to know if yall have any advice or recommendations on how to get this done.
I know the value of my time and I know how expensive maintaining a highYou’re underestimating the value of your time
You’ll need a front sump pan for the LS.
I can’t imagine how you can use the key for the LS starter with EIS in the way but you can add a separate starter switch. I don’t know if the fuel pump will flow enough for an LS but at least the pump isn’t in the tank. Is the LS throttle by wire?
Sixto
98 E320 wagon 197K miles
I've already had to drop in a new alternator into my e class at 137k. I don't want to deal with the exorbitant prices of Mercedes parts. I can buy everything needed for the swap for the price of that E55 without the fear of paying way too much for parts134k is high mileage?
lol bruh
I have a daily driver already so I want something that i can reliably make more power out of if i need it to. My e class already has no AC as needs other work so making it a high hp project is the most fun i can haveI think an LS swap would be a great engine to put in the w210 if you have the right reasons and are willing to sacrifice some amenities. What are you expecting to get out of it? A high horsepower car with TONS of aftermarket support or a reliable daily driver? If you happen to want a simple daily I’d recommend an e55 as well.
No need for it. 4l60e is attached to the LM4. More trouble to get a 722.6 adapted to it and not have the same control or aftermarket support as a 4L60 or 4L80.Welcome to BW williams805,
722.6xx with the OFgear kit?
(only thinking aloud....)
Speaking of.... Remove the original ECU and TCM, ABS and ESP will disable itself. It will just straight up disable and not work at all. My E55 with manual trans has no ABS or ESP because I disconnected the TCM. If I want traction control back, I need to get a ESP module out of a manual car.I'll try to keep ABS if I can.
E55 diff is the same as E430 diff. Same 2.82 rear. Can also use W220 diff, I believe they are also 2.82.If can find an E55 rear for a reasonable price
