locked only key in trunk of 1998 SL500
14K views 25 replies 15 participants last post by  e-420
Yep, I somehow managed to 'get the bean above the frank'... I pushed the keyhole/button on the trunk lid, popped the unlocked trunk, put in everything I was carrying, shut the trunk... and the trunk locked. Not sure what happened, but I now need a solution.
Few notes:
  • The lock is not broken, its just locked.
  • I have access to the interior of the car but the trunk button wont work without the key.
  • Its a 2 seat convertible, so I cannot remove the rear seat and use a pump on the air hose to pneumatically pop it.
  • I don't know how to take the trunk button out of the dash... if I could I might be able to hot wire it, by running a hot lead to the terminal on the button, to connect the circuit.
  • I used a hole saw to cut a hole behind the license plate, near the bottom, but apparently this only works for newer cars; nothing is there besides what looks like a black rubber air-hose that comes out of the locking assembly, and splits in a T and has 2 smaller diameter white lines going in each direction. (I assume this is an outlet? Otherwise could I pump THAT?)
...the problem is since the assembly is 'right of center'... and the key on this model is not 'up top', but on the 'top right'... I would have needed to cut that hole between the lock and the assembly, not where I did. And if I cut where I need to, that leaves me with an exposed hole, not covered by the plate.
Another option is hire a locksmith to drill it out, which I hear is $350 or so, and smashing out the rear taillight. I guess I could drill above and to the right of where my current hole is (more like top right of the plate area) and maybe see if I can get to the rod that way. Of course I have no idea what this really looks like, so maybe I'm just adding an extra step before I smash out the light.
Thoughts? advice? Moderate ridicule?
Hey relax! You've already laid the tracks, so all we gotta do is back it up! haha
If this doesn't work, I guess other options are: -
1) activate central locking from cabin
2) spare key?
3) break out rear tail lamp to get access to trunk.
#5 ·
yeah, no spare key.
wait, before I break out any taillights, lets go back to this air hose that I see in there... When I look in the hole towards the right, I see the assembly with an air hose coming out toward me (and the center of the car). It then splits in a T and becomes 2 smaller diameter, stiffer, white plastic lines.
Can anyone tell me if what I'm seeing is exactly what I need to blow into to pop the trunk, because if it is, then we now have a new no cost way to get in to trunks:)
#9 ·
Locksmith is $350
The car just came down a month ago, used/new to me, but the paperwork is up north.
I also already went to Benz and they told me the cheapest option is to break the tail light, so apparently they don't do cheap keys down here in Lauderdale.
I finally found the right activator I'm dealing with, so now at least I know what it looks like:
1994 2002 Mercedes SL Class Trunk Lock Assembly | eBay
...so I drilled another hole in the bottom right corner, behind the plate, and got right to that black plunger... Then I grabbed it with a pair of needle nose pliers and pulled it to the right.... Nothing.
Ok, so now I'm completely lost. What the heck has to happen for the trunk to pop. The key turns a cable and the cable pulls that black plunger.... Which is what I did.
Anyone?
#11 ·
What a shit show dealer, maybe call another one, I have never heard of that response..Dealers provide any keys as long as you have vin and title ?? Ridiculous..Having said that the lock is vacuum actuated, not sure if it locks or unlocks under vacuum, with limited access it would be hard to pull a hose, quite a headslapper...the tail light is a fortune too and you may not be much better off than you are now
#15 ·
did you push the key button with your finger??
No. He poked himself in the eye! Jeez! ;)
Anyone?
On my SL ('91) there's an 8mm dia steel rod that connects the push button key lock actuator to the lock mechanism. Its about 6 to 8" long and runs horizontally. When you push the lock button, the rod rotates (twists) and engages the flat detent of the lock mechanism which rotates and releases the lock.
You cannot access the mechanism or release rod via the license plate light cover lens because access is restricted by the trunk internal lining.
Even if you managed to drill a hole in the right place so you could see the release rod, I still don't believe you would have enough purchase and leverage on the rod to release the lock.
The license plate light and drilled hole methods are only viable where the owner has accidentally locked himself out and has also either already removed the internal lining or push button key lock.
IMO the options are either actuate the central locking from the cabin (my SL has a toggle button on the door card to do this), or get a spare key, or break the tail light, as previously suggested.
Good luck, and don't forget to report back with your progress!
#12 ·
What Dale M said. You cannot access that trunk from the interior of the car. The only way you can get in is to break the right taillight or in your car or in your case use a key.
I was in that position when I installed a new latch and didn't take off the rear lining to make sure the actuating Rod was attached to the latch. So at least you are lucky in that a key will work.
Do a search to read about my travails.
#26 · (Edited)
you CAN get in w/o breaking the tail light.!!!! verified it. take out the license plate and the RIGHT license plate light. from the opening you can with a hooked tool, grab and pull the actuating rod, or if the rod is loose, attach the rod. with the trunk locked AND the rod attached you may need to pop the rod out and release the latch manually.
another member didn't get the rod in properly and couldn't open his trunk. having seen how it was attached, I verified I could get in through the right license plate light hole and actuate the lock to pop the trunk. IIRC he was then able to do the same and open his. it does take some right angle tools etc. but I did it and so did he. However in these cases the rod was loose, but I think from seeing how the mechanism works one should be able to open it even with the rod attached.
#14 ·
I thought I read someone removing their.....
license plate light cover lens.
I don't remember if it was the right or left side. :|
They removed the little clear lens cover & it gave them access to the rod that releases the trunk latch & they were able to open their trunk. :eek :grin
Good luck!! :grin :angel
#16 ·
Just about to break the right side taillight but let me clarify a few things...
  • I have two, 2" holes (from a hole saw) cut on either side of the actuator, which is almost upside down in the image. (The black plunger faces RIGHT)
  • I ALREADY disconnected the T and tried to blow air into the black line that goes into the LEFT side of assembly (you can see the nipple in the image below) and got back-pressure, like the air was hitting a one way valve.
  • I ALREADY have access to that plunger on the RIGHT side, that is actuated by a CABLE (not a rod), similar to a brake cable on a bike.
  • I ALREADY pulled that plunger all the way to the right, and not only does that not open the trunk, but it gets SUCKED back in to the unit.
...so basically, the question is, is there a COMBINATION of things I need to do to open whatever that valve(?) is that is giving me back pressure. For example, pull the arm all the way to the right, WHILE blowing in the black air line?
#20 ·
[*]I ALREADY pulled that plunger all the way to the right, and not only does that not open the trunk, but it gets SUCKED back in to the unit.
[/LIST]
...so basically, the question is, is there a COMBINATION of things I need to do to open whatever that valve(?) is that is giving me back pressure. For example, pull the arm all the way to the right, WHILE blowing in the black air line?...
New territory for me. Your lock is different to mine.
I reckon you maybe right. Pull on plunger and at same time apply vacuum to air line. If that doesn't work try same thing but apply pressure to air line.
You need to replicate what happens when the key is turned in the lock. I.e. the cable pulls the plunger, and at same time the central locking pump applies pressure (-ve/+ve? not sure) to black air line.
If you have to break the tail light, try to just break out the reflector/lens. You should then be able to remove the bulb holder behind.
