So my SL is great but, id be a whole lot better if it had a manual transmission in there. I'm dead set on this, however, I would like to know a bit more before I start buying stuff. Mechanically I'm pretty much all set. I can fabricate my own adapter plate and modify things to work accordingly. My biggest concern are the electronics for which I have limited knowledge in. What do I need to know and do to get my car to work with a manual transmission?
- Can the transmission control module be removed with no consequences?
I'm assuming, and correct me if I'm wrong, it's just gathering info from the ECU to let it know when to change gears. So its not a vital part of engine operation. If that's not the case...
- Do I need to reprogram the ECU so it knows it has a manual tranny? Or can I trick it into thinking it has the original tranny?
all help/knowledge is very much appreciated, Thanks.
