In another thread, I found:
"Warning never charge the car with the key in the ignition,never put a jumper on it with the key in the ignition,never charge the battery via the battery post and a good ground with the key in the ignition."
My 2001 E320 has 4,800 miles on it and while I drive it once in a while, I like to run the engine a bit at idle but I don't think it does much for charging the battery and I've ruined two over the years due to not charging it enough.
What is the proper way to use a battery charger or trickle charger to top off the battery?
Thank you,
Thank you,
