Art, thanks for the info regarding the 12v supply to the amp trigger. Couldn’t get back to the forum sooner due to travels.
When the output was checked for the amp trigger wire it was found to be same for OEM and the replacement pioneer (640mA). So that was not the problem.
Checked the harness wires individually and found them working as well.
After reading Art’s post regarding connecting the wires directly, tried connecting the speaker wires to amp input directly, instead of the RCA posts provided in the back of the pioneer HU (see attached pdf for connections info). And guess what, it worked. I don’t know the technical details well enough to explain why the (HU amplified) speaker output is working through the MB’s amplifier, but not the post designated for connection to the amp. Checked through all the menu options to see if it can be switched through software – without any success.
Just bought some female RCA plugs, soldered them on to the speaker output wires and connected them to the harness. All operating just fine:smile.
I must say, the sound quality through a $120 aftermarket radio, albeit 14 years newer, sounds a lot better than the MB OEM radio/cd changer. Having a blue tooth is a big bonus. I will miss the VSS automatic volume control, as I find myself adjusting the volume more often as the ambient noise level changes.
Also, for anyone considering radio replacement. The Pioneer kit ADTVA133, makes this radio replacement exceptionally easy. Only modification to the vehicle required was the removal of the plastic guides on the inside. A simple hack saw did the job in seconds (a good serrated knife would do in a pinch). The new phone mike is attached to the steering column adjacent to wiper stalk. The small plastic panel to the right of the steering column (where the window fold switch is attached) was gently pulled out. There is sufficient space between the steering wheel and the plastic panel for wire but not the plug. It is an easy access to the radio cavity from there.
Though it was a little difficult to get the speaker output issues sorted out, this is a lot better HU (total cost including the kit, harness, & plugs $175) than replacing with used OEM radio from EBAY for $280.
Thanks again Art, CGL, and Mike
