I have noticed that after starting my car all of my lights are flickering slightly and in sync - headlights, taillights, cluster, console, footwell, etc.
This is with AC off, blower off. engine cold idle (~1200RPM).
I don't know yet if it does it after warming up the engine but the car drives fine and the blower works fine, so there is enough power to run that.
I have a new alternator.
I have a fairly new battery that I keep on a tender and was fully charged when I started the car tonight.
Battery negative terminal is securely bolted on. No corrosion on either terminal.
The grounds for all of these lights are all over the place through the body so perhaps it is where the battery connects to the body? Where is that?
It looks like the battery connects to a common point for fuses one and two and then goes to the light switch. Maybe the problem is in the light switch? Hmmm.
Any other ideas for troubleshooting?
Thanks, Andy
Thanks, Andy
