Had a problem that ESP, BAS,ABS lights came on and car was stuck in one gear. When I stopped I put into PARK but then I could not engage gear except using the pencil to manually do it. Turned engine off and it would not start again - would not even turn engine over. Was told by a Merc specialist that a fuse would be blown in the ECU box which would need replacing - he was spot on. I am told there is a small fan under the ECU box that needs to be replaced - any idea what is involved in doing this job?
MFK
MFK
