DIY Adjustable Rear Camber Arms
112K views 102 replies 32 participants last post by  amoffitt
#1 · (Edited)
Hello everyone,
Originally from, DIY adjustable rear camber arms - 190 Revolution
I'm just crossposting this so that the word gets out. I know some guys might not be on this board and 190Rev so, 190Rev member 16V4NRBRGR did all the research and whatnot so all credit goes to him for his hard work.
Mine totaled around $85 shipped.
Edit: www.speedwaymotors.com is where to buy this stuff from. forgot to mention that.
Note: when ordering, it'll want you to select the angle of the one shank, just pick straight.
Also if you don't have bolts to mount the arms up with you can use the Mercedes kit 2103504506 is the part number for it. You'll need two.
You'll also need eight washers to go between the nylon and the bracket on the subframe/wheel carrier
My original adjustable rear camber arms:
New ones pre-assembled. courtesy of 16V4NRBRGR,
New one installed.
I think they're pretty sweet. Price is amazingly right too. I replaced all my other links in the back when I installed these. I had to use an angle grinder and cut out my old camber links. They were RUSTED.
I used the bolt kits that were in my rear end kit from Meyle, which used triple square heads. I had to go to autozone and pick up pack of tools for them.
Any questions let me know, I'll do my best.
Discussion starter · #3 ·
This suspension setup was used on MANY Mercedes Chassis...So this kind of modification is valid and should work on the following chassis:
w124,w129,w170,w171,w201,w202,w203,w208,w209,w210
Discussion starter · #8 ·
You don't have to, if your goal is lowering the car and adjusting for camber no. If you have plans of tracking you car or other things then you could, but I'm not sure about what parts are applicable for them.
I just replaced my camber arms and replaced the rest with stock replacements.
Discussion starter · #10 ·
I'm not sure about the adjustment of the other bars, i just have the camber ones installed, my car aligned up no problem.
Discussion starter · #12 ·
Im running 17" wheels right now and dont have any clearance problems, and my car is lowered. Granted I am running only 40 series tires though.. I'm not having any clearance problems.
I looked at K-Mac's website didnt see price listings for the rears but the fronts were $400. Slightly out of my budget.
Discussion starter · #15 · (Edited)
Discussion starter · #30 ·
Mine are still on and going strong.
Almost three years later, no complaints here.
Discussion starter · #44 ·
Sorry, I know I'm in the wrong forum but can't hurt if I can get some answers. Does anyone knows if the speedway parts kit fit a W211? I have 19's on my car and it's eating up the inside of the rear tires. Thanks in advance.
The 211 uses a multi-link rear suspension similar to its predecessors however I was looking at pics on this thread :
DIY W211 Rear Springs/Bellows (Arnott) - MBWorld.org Forums
and it looks like the camber strut bends around the shock/strut/airbag which will be a problem for the speedway kit as its a straight arm. Unless your w211 does not have that airbag and can take a straight shot arm... then you'd be ok.
Discussion starter · #45 ·
"Cheaper" basic parts with pink paint that flakes off @ twice the price!
The 4 bar ends are welded, as are the RodSupply ones (not forged) and the tube is Aluminum (not steel) which will strip easier.
DIY setup is much better option. Nylon inserts work better than Poly (which are prone to squeking without special grease). I used marine grease on mine and not a peep for the last couple o' years!
Do you have a link to the nylon inserts? I've got poly and they do squeak! Do you have a link to the special grease that makes them not squeak?
Discussion starter · #48 ·
I haven't seen the nylon inserts available separately.
There are several manufacturers that make a grease to be used with poly suspension bushings. It's not an internet myth that you shouldn't use a petroleum based grease on poly bushing. Every poly bushing manufacturer warns against using petroleum grease as it breaks down the poly over time.
Yes, a silicone based synthetic waterproof grease is the correct way to lube poly suspension bushings.
Energy suspension makes one w/ teflon; Energy Suspension Formula 5 Prelube
Spohn also makes one; Spohn Polyurethane Bushing & Chassis Grease - 14 oz Tube - AllOutRacing.com
Here's another; polyurethane lube :thumbsup:
Hmmm,
SuperLube? I've got that stuff handy. I've also got a box of replacement poly bushings. Maybe this weekend I'll pull the bushings out, replace them and coat them with SuperLube.
Discussion starter · #50 ·
So I'm considering asking one of our manufacturing guys up at work to see about machining me a set of nylon bushings..
Any idea what kind of nylon would be best?
McMaster-Carr
Maybe?
http://www.mcmaster.com/#standard-nylon-rods/=srqh3u
Discussion starter · #52 ·
I'd lean toward the MDS or Glass filled. Both are used on other automotive apps and are higher in heat, strength and fracture resistance. And if anyone questions the strength of nylon compared to poly, just try to find a locknut with a poly insert. Ain't gonna happen! :thumbsup:
Hmm the glass filled one does not indicate lubrication stuff...the MDS one was self-lubricating... will the glass one squeak I wonder?
Discussion starter · #55 ·
Hello All,
Just when through the whole thread and looks like I ordered the wrong part with the 11 degree shank. I just want to make sure this is incorrect so I can send them back to Speedway to get the correct parts before tearing the car apart first to find out then that it is incorrect.
I have a 2000 W202. All ends should be straight. Correct?
From what I can tell by my googl-ing of rear suspension pics, yes. You might want to have a look at yours just to be sure.
Discussion starter · #57 ·
