Disclaimer -This DIY is a blog of how I changed the compressor and condenser on my son’s 2009 ML350 4Matic which had over 163,000 miles. These are not instructions for you on how to do the job on your car. Therefore, if you attempt a similar feat and the engine falls out of your car, the neighbor’s cat starts an affair with your dog, your retirement portfolio plummets, or you just get a freaking hangnail after reading this post, I am not liable. So there.
Radiator suction fan malfunction which caused overheating of the AC circuit and the compressor to fail. Failed compressors usually spew particles downstream the system. Just groovy.
- Symptoms
No AC in cabin and no change in compressor noise when AC pushbutton on/off. Engine revs constant with changes in pushbutton state. LED light on button works. Interior cabin fan was working properly. - Auxiliary fan (aka electric radiator suction fan) did not start. Should start concurrent with AC pushbutton depressed, red light showing and stationary car at any temperature. (Automatic shutoff on this variable speed fan after car exceeds 25 mph)
- Fuse for AC and fan was not open.
- With compound gages and manifold installed on the AC, Low pressure R134 stayed constant at 100 psig with engine off/running, and AC pushbutton on/off. High pressure around 110 psig with AC button on.
- Low pressure suction line (next to Schrader valve) was not cold – ambient temperature immediately after starting. My son previously reported this particular line had become very hot – which in technical jargon is a very bad no good thingy.
- At this point, it looked like the radiator suction fan was the culprit for a chain of unfortunate events. With the engine off, I removed and reinstalled the electrical socket on the passenger side of the fan shroud. Subsequently, the fan started when the engine started and AC pushbutton depressed; but the AC did not work, and the R134a low and high suction pressure readings did not change.
