Cleaning
purge valve,If the code did not clear when you got a new gas cap,or flipped the gasket.Clean the purge valve,it is a little pump that sucks a vacuum in the tank and gas lines systems,so it sucks fumes into the engine so they don't get into the atmosphere.
it is located .....
pop the hood,look in the drivers side of the engine compartment,in front of the area where the brake master is you will see a little black can looking object.
Labeled ---MOT---
with the engine running you should hear it clicking like a little drummer.to check it's operation,just start the engine and put a screw driver tip on it and listen with your ear pressed on the handle-------cheap stethoscope------
you should hear it doing it's job.Sometimes they get gummed up,so lift it off the
W shaped mount and gently pull off both enter and exit hoses,get some maf cleaner(CRC brand) and put the tube that comes with the crc on the sprayer.Insert the tube into the hose and spray for a few seconds,repeat to the other hose and the the valve itself,let air out for 10 minutes and reinstall both hoses and put it back onto the W shaped mount.
Start engine and enjoy.
ohlord
some pics to help you
it is located .....
Labeled ---MOT---
ohlord
