My two center air vents have stopped blowing. They do not blow hot or cold air. Any suggestions on repairing them?
Ensure the center 'dial' underneath the vent is turned open. The center dial runs the center vent.rwvw415 said:My two center air vents have stopped blowing. They do not blow hot or cold air. Any suggestions on repairing them?
First diagnose the cause of the problem. Follow the attached procedure to put your climate control unit in a diagnostic mode and monitor control inputs and outputs. This is for cars 1997 and later. Refer to the table below (typed by gsm-decode in a thread a few months ago). In particular you are interested in items 63 and 64.rwvw415 said:My two center air vents have stopped blowing. They do not blow hot or cold air. Any suggestions on repairing them?
FWIW, I decided to take some baseline readings by following the above Climate Control, etc. procedure for data collection. Here are the values I received after reading MERCEDES-BENZ: A/C Diagnostics.bobterry99 said:This is for cars 1997 and later.
I decided to take some more readings by following the same Climate Control procedure for data collection. Here are the values I received today, 2/10/10.FWIW, I decided to take some baseline readings by following the above Climate Control, etc. procedure for data collection. Here are the values I received on 8/5/07.
Sensor# - Description - Unit Value
01 Inside temperature °F = 74
02 Outside temperature °F = 79 (sitting still, engine running)
03 Heater core exchanger temp. °F = 58
05 Evaporator temperature °F = 47
06 Engine coolant temperature °F = 192
07 Refrigerant pressure Bar = 14
08 Refrigerant temperature °F = 127
10 Blower control voltage = 12.5
20 Auxiliary fan control current mA = 00
21 Engine Speed x10 RPM = 0600
22 Vehicle Speed MPH = 000
23 Circuit 58d (% of batt. Voltage) % = 000
24 Battery Voltage = 13.9
40 A/C Controller Software Version = 03
41 A/C Controller Hardware Version = 03
42 Variant Code 1 = 11
43 Variant Code 2 = 6-C
60 Roof OPE/CLO = open
61 Left side air outlet(open), knurled wheel potentiometer Volts = 4.0
62 Vacuum actuator 46, feedback potentiometer Volts = 3.5
63 Center outlet(open), knurled wheel potentiometer Volts = 4.1
64 Vacuum actuator 47, feedback potentiometer Volts = 3.5
65 Right side air outlet(closed), knurled wheel potentiometer Volts = 0.8
66 Vacuum actuator 48, feedback potentiometer Volts = 0.9
BRO,Hi, I have just fixed an identical problem on my 92 R129.
In my case it turned out to be a popped out connection on the distribution block under the bonnet. This had disabled the center vents, and the side vents worked, as they default to on, but were not swithing off.
Heaps easier to get at than Y11 too!
The distribution of vacuum starts under the hood in the computer modules box. Vacuum from the manifold goes into a 7 way distribution block, via some isolation valves to the transmission and others. The Red-gray one is the feed to the vacuum reservoir for the A/con. My line was a little tight and had pulled out, possibly when some work had been done on the car a while back.
Hope this helps. The diagrams in the R129 Classic DVD are very useful...
GregE.
If the climate control unit can not perform diagnostics, then it seems logical to me that it can't perform some of its basic control functions as well. I would look for a used replacement module.Tried to diagnose the system but it did not work (I done it before).
Read the bottom of the above post #3.I am also having a problem with my footwell vents opening,only the upper vents would blow heat!What is the diagnostic check on my 1999 sl500?Thanks speedmaster 2.
Thanks for the feedback this may help me to find out if my mni fan that draws air into the vents actually works.I tried the tissue for the interior temp sensor at the upper console,and it stayed,I cut the tissue slightly larger than the vent,I found that it is a very light air pressure pulling the tissue in,The draw of air is mostly on the right side of the vent.
you may also have a bad check valve in the vacuum hose between the engine and interior. That line should have a check valve that holds vacuum inside when the engine looses vacuum.During my recent oil change apparrently I disconnected the vacuum hose from the intake manifold. Put it back and presto, I have center vents blowing air again.
