Brake Booster / Bremsgeraet ATE T51 rebuild. This is how I did it.
Hello
Perhaps this will help someone else out there as there seems to be a lack of information.
The Ate T51 brake booster was used on heaps of Mercedes cars from the 1960s up to the 1980s and perhaps even later?
Some use a single piston / diaphragm boost and other use a tandem or double piston type. The mercedes fintail service manual calls the tandem booster T51 / 200.
This follows my other thread regarding the brake booster as seen here:
http://www.benzworld.org/forums/general-mercedes-benz/2753073-brake-booster-what-wrong-when-leaks.html
I decided to rebuilt the booster because they are quite expensive new and also used. The used ones seem I looked at come straight off wrecked cars and the condition was questionable.
My bosster was completely rusted out underneath. From the top it still looked great and it still worked (actually boosted) when braking !!
First I opened it by placing it in a vice with the front down. I clamped it in the vice by the 2 threaded studs for the mastercylinder. I put nuts on them.
I used a 2 or 3" webbing tie-down strap and wrapped it around the booster main body. This was tied to 1 yard a 2" pipe. I used it such that the strap would tigten itself more when I levered the pipe. Same principle as an oil filter wrench just muych bigger.
It was tough and I needed a lot of force but eventually the booster hald turned enough to unlock the crimps and it popped off. Please ignore all the mis infotramtion out there about a a killer strong spring in there. The spring is similar to a bed spring and the booster will pop open no more than 5-6". Keep it in mind anyway.
Next I removed the inside bits.
The 26mm nut on the front piston should be undone for this but I could not get it loose at this stage because everything was turning and it would have ripped the diapragms.
I popped everything out carefully in one lot. The chamber divider also needs to be turned so it can pass through the crimps at the front.
Next I repaired the housing by cutting out the rusted section and fabricating replacement parts from 2mm (80mils?) galvanised steel I had left over from a trailer floor I recently replaced. That took me a whole afternoon as the rear membrance seat is part of it and was tricky to get right. I made the section out of 3 separate parts and tacked them in place. Once it all looked good, I welded everything in place being careful not to put too much heat into anything. I used my mig welder and sheet metal welding techniques.
After this, I painted the inside with a really thin runny paint and thinner (turps in this case) mix. That was to find and also seal off any pin priock holes left by the welding I had 3 tiny pin holes.
I also had to make 4 new crimps in my replacement section. I did this by making tiny slots with a really thin cutting disk in the dremel tool and then forming the crimps by htiing them in with a rounded drift (a ground off bolt) and hammer.
Then I painted the inside properly with the same paint.
More in the next part...
