whats the best recommended spark plug for these trucks ? I called the local real autoparts and they had a few brands available. I assume this takes a platnum plug, looks like 16 of them.
I thought I read it somewhere that 99ML came with multiple plug... Did both 99 and 05 ML come with single tips plug (7422)?Bosch 7422. No fancy pancy multi tip plugs please.
Ironically I did the plugs on my E500 and it had the factory installed production plugs in it.
They had the MB logo on them and they were NGK plugs. When
I did the ML they were Bosch
with the MB logo on them.
The OE NGK plug is the IFR5D10 also know as the 4696.
I would go with the Bosch and save some money.
Just for giggles I went on to EPC net and got the OEM part
0041591903 which is superseded by 004159190326.
$8.75 list at the dealer and $6.04 at parts.com
Turns out to be a dice roll as to what they might be from a dealer
or online MB OEM like parts.com.
They will have the MB logo, but could be made by Bosch, NGK or Beru.
I am going to call the dealer and see what they have the shelf. I am
quite curious now. EPC net had 3 numbers listed and then a not that
said 0041591903 is now the stocked number. Then when I went
to try and order them the number 004159190326 came up.
I totally concur on that; I too recently changed my spark plugs to the OEM single-electrode Bosch (7422) and oh my Lord my ML55 became like some sort of wild animal at full throttle..I just installed 16 bosch 7422's (also seen as known as FR8DPP33, F8DPP33) and replaced the wires. The difference was like getting a stage 1 chip tune. There is more low end torque and more hp at the top.. the engine just feels and sounds better. Don't be seduced into the marketing for multi-electrode plugs.. just go with stock.
Thanks for that confirmation. I don't serious DIY that much anymore - just lost interest, Before the TTZ32, I used to have a TZ31 and I recall using a different heat range plug on stock motor because I thought I knew better. It was a very bad idea! I don't think a lot of us normal operators quite understand the role the plugs play in the overall motor temperature....
I know an owner of twin turbo Z like yours and he has it all pumped up. He runs one step cooler and the car has better response and is smoother throughout the entire rpm range from idle to red line.
Completely agree. I'm surprised the ones in your VW went that quickly. My Beetle is parked outside all the time. It has about 53K on it and I went through the first change at 45K at dealer. They didn't recommend plug cable change,..., but they probably never checked them. I'll have to keep an eye on them. Stupid Question: Is there a DIY impedance check tool?The only way to really know is with an impedance test. ...
What happens if we put the 0 Ohm wires on a street car?...
I have a set of Nology wires on the track car and they read almost zero. Whole different
ignition and wire construction.
