I have started collecting all the data I can find for the wire diagrams as of today. IF YOU HAVE WIRE DIAGRAMS FOR 2003 AND UP PLEASE SHARE. My plan is to learn a removal hack. I have purchased coil overs, so I will eliminate the need for "extra" stored power for the ABC. Simply converting to a dual charging/powered battery system will be easy. Deciphering all that runs through it, for absolutely no reason I am sure, will be the fun part. From all my current research it seems the BCM is nothing more than a severely over engineered device designed to separate an active power supply from an as needed power supply...could have been done with a few relays very cheaply without fear of your car going up in flames. Currently thinking of overlaying a new charging system while leaving the BCM connected to the ECM for warning light elimination, with no real connection to charging of the battery and or batteries. While also considering that with ABC eliminated the dual battery set up in general can be eliminated. If there are any other's out there actively searching this and working on something please jump in and lets figure this out. If a hack kit can be built it can be sold!
