My auxiliary cooling fan does not seem to be working in my 1983 300D. It will come on if I short out the wires on the AC reciever/drier, however even if the temp gets into the red, the fan does not come on otherwise.
Where is the temperature switch which controls the fan? Is it the sensor located on the thermostat housing?
Also, wherever that switch is, can I diagnose things by simply shorting or grounding out its leads?
Thanks.
-Jeff
Thanks.
-Jeff
