1998 W140 S500
Symptoms:
- When I step on the brake, the light bulb warning light on the dash lights up. When I release it it goes out.
- When I step on the brake, the instrument lights, climate control light, and radio light all come on.
- When I turn on the parking lights, the center brake light is lit. If I step on the brake it gets brighter.
- The ASR light comes on and the car goes into limp mode when ASR is enabled. It runs fine when ASR switch is off.
UPDATE:
I found a thread that indicated the center brake light could be the problem. I open it up. No signs of melted wires or heat problems. I completely unplugged it and still the same symptoms. It wasn't a total waste of time though. I was able to fix the rubber gasket where it touches the window.
Brake light switch?
Don
Symptoms:
UPDATE:
Brake light switch?
Don
