Apologies in advance if this is the wrong sub-forum. This is my first post here.
I recently leased a 2018 E400C. The Adaptive Highbeam Assist feature appears to be non-functional (or perhaps "worthless" would be a better term). Instead of putting the car into high beam until it senses an oncoming vehicle, it apparently (so I was just told by a dealer Delivery Specialist) never puts the car into high beam unless there is zero ambient light. Even star light (if he is to be believed) during a New Moon will be enough to prevent high beam from being engaged, unless the stars are occluded by clouds (perhaps I exaggerate, but not by much).
For the record, my rotary light switch is set to Auto, the combo switch stalk is pushed away (#1 position, as identified on p. 109 of the Operator's Manual), the green "low beam" in on, on the bottom far right of the instrument panel, and, immediately to the left of it, is the "A" indicator lamp, indicating that Adaptive Highbeam Assist is engaged. What I never see in this setup is the blue high beam indicator, or the high beams, themselves. Finally, high beams do work if switched to manually (either by pulling the combo stalk to #3 position temporarily, or rotating the switch to #5 and pushing the stalk to #1).
Has anyone actually seen high beams with Adaptive Highbeam Assist engaged?
TIA,
Mark
TIA,
Mark
