722.9 and Circuit Board Medics
5.6K views 8 replies 6 participants last post by  rudeney
You are 100% right about the electrical connector. When replacing the fluid pump on my CLK550, I broke this part, too. And that was with the transmission out of the car with plenty of room to work on it. It just could not get it to come loose without putting too much pressure on it - pushing from the outside, and pulling on the plate from the inside. It broke the collar and pulled its electrical connectors from the Mylar ribbon cable. i was able to use JB Weld on the broken plastic collar, and re-solder the pins to the Mylar ribbon cable. I verified continuity and everything worked fine.
It is good to know about Circuit Board Medics. I see they also do work on instrument clusters. Thanks for the info!
Rodney, I just did the same Breaking connector while pulling valve body On my 12 year old W463. Did your weld hold for long? I’m worried that fluid will penetrate the plastic collar also. But, would much rather fix then replace with all the coding issues.
