this doesnt always happen but sometimes when i let off the throttle at speeds between 25-35mph, I can see the RPM's drop down to 900 or so, which I believe is the converter unlocking. When I get back on the throttle, the RPM's will climb to 2000rpm where the RPM's abruptly drop down to 1700rpm (converter locking up, i'm guessing) That abrupt drop is so sloppy, it jerks the car. Any ideas? No, I don't have glycol in my ATF...i've tried the sneaky ecu reset via the gas pedal, as well as disconnecting the battery. fluid and filter are fresh and regularly maintained. no leaking at tcu connector plug either.
i decided to take a video, forgive the crappy iphone footage...
forgive the CEL, freaking worthless secondary air pump...
video 1: demonstrates the problem, at constant throttle, no problem. i let off the throttle, you see the rpm's drop, then i get back on the throttle and it jerks back down to 1700rpm
video 2: after some WOT passes, the converter stays locked on decel, as it should. this is absurd that i have to smash the gas pedal to avoid this crap
cliffs:
-traveling between 25-35mph
-let off throttle
-get back on throttle
-jerk
cliffs:
-let off throttle
-jerk
