I know this is a little old thread, but I would like to share my compressor removal!
First of all, I have an 85 380SL, so not sure how or where but I believe all engines of that 107 designs are situated the same. Soooooooooooooo
I didn't remove the fan or the radiator or anything else that takes half a day and huge mess! All you need to do is unbolt the power steering pump, which is 3 bolts, than one hose that is closes to the front of the car. Plug the end cause the power steering fluid will leak out! I used a tight hose with a cap.
Next, I moved the power steering pump upwards and to the side.....you have to tilt it a bit so the fluid doesn't leak out. I lost maybe 5-6 Table spoons, which I added after the job was done. Anyways....There is a bracket thats bolted to the head now with 4 bolts (10mm socket did the job perfectly) After that, we unbolted the 2 front Allens bolts as specified above in prior posts. Now make sure, the crankshaft is aligned
I'm sure most of ya will say, huh???? Yeah, believe it or not, the crank has a notch in it to align it to the bottom allen bolt so you can put a nice H6 socket straight in!
After that, there are 2 bolts behind the compressor....easy to get to with a swivel...Also, those have to be undone from underneath the car. Make sure as always you have the car on jack stands....
I personally (after the system was properly evacuated) took the pipes off from the compressor by unbolting one single bolt, holding both of them in....After that, the AC lines came out, and the compressor slipped right out....Well, it took 2 people to take it out cause this thing is at least 50 lbs!!!
I pulled out a nice hardly used Denso compressor out of a 91 420SEL, and even the aluminum compressor bracket fit as it supposed to....Needed couple spacers in the rear holes, but the fronts along with the belt tensioner worked as oem/stock. The r134a compressor fit right in.....total charge was around $100 from the junkyard....it was still almost new and the hoses had part# tags still attached to them.....
Well, this is not a how to convert, it's about taking the compressor out thread....sooooo, just saying, you don't need a whole day....My buddy and I did it in about 3-3.5 hrs....but the car does need to be up.....
As a strong suggestion...USE 6MM SOCKET MOUNTED ALLEN KEY.....it will save you headache....I promise you. Yes, they are a little pricey, but I picked one up at Lowe's as single unit for like $7 or so?
