2004 C230 Kompressor Coupe emissions
2 reading
321 views 11 replies 5 participants last post by  C230 Sport Coup
Hi All
We recently bought a 2004 C230 Kompressor coupe, it's a bit of a project.
The main (current) issue: -
The low fuel light flashes and it causes the check engine light to come on.
The code is p0457 and our scanner suggests checking the gas cap. The light comes on when you are sat at the traffic lights idling for a few mins.
We bought a new gas cap from mercedes dealership and it didn't cure the issue.
we smoke checked the system and the charcoal canister behind the rear passenger wheel was broken/cracked, so we got a "new to me" charcoal canister with the valve thing on top from a junk yard. Still getting the code.
We removed the purge valve in the engine bay. It holds a vacuum and opens when you give it 12 volts. So it appears to be working. When we removed the purge valve one of the hoses tore (perhaps already torn?) so we replaced the hose. Still getting the code.
We bought a new fuel pump with a tank pressure sensor (the one on the drivers side of the car, under the back seat) and we still get the code.
We can't register the car in our name in AZ with a check engine light.
Any suggestions as to what we can do to stop the annoying code?
thanks
Gareth in AZ
2004 C230 coupe
1978 Spitfire
1984 TVR
2007 Saturn Sky
2005 Crossfire
2006 A4
2016 Equus
2012 Malibu
2025 Camry
Yes I have a car hoarding problem.
#4 · (Edited)
How does the car drive? How is your mpg? Doesn’t everyone have a guy or know a guy who knows someone who can get the car to “pass” for a couple hundred more?!
in all seriousness, I’ve been dealing with this same thing with my car for over a year now. I’ve done a lot of what you have done.
I was able to get a gas tanks window of opportunity to get it to pass. I code cleared it, went through the whole evap cycling process a few times around 3/4 tank until my scanner showed me the car was “ready” to cali standards for the smog check. Ran to the smog check place right away.
The annoying light stays on since. Interestingly, I got a flat on the rear pass and the light went off with the spare driving until I put the new one on. Strange.
Now that it’s passed I have a couple years to chase it down. The car runs well and I have another year to chase it down
#7 ·
The car runs great. I haven't checked the mpg but it doesn't appear to be running crazy rich. We replaced the plugs and they are not black/sooty.
If we kick the car into neutral when we are stationary at the traffic lights it doesn't flash the light and give us a code. I have driven it slow, fast, hard, carefully and ran it in my garage with a swamp cooler blowing on it (probably 105-110 degrees outside today) and we are down to two incomplete codes. I believe that we can go through AZ emissions with one incomplete code.
the incompletes:- evap system monitoring and secondary air system monitoring.
If we can get it to one incomplete, we will immediately go to the emissions station and if it passes we have 2 years to sort it before the next emissions test.
#10 ·
I had a similar experience when I bought my 2005 C230 about 8 years ago. My car had a P0456 code instead of P0457, but both codes are EVAP system codes. I solved my problem by replacing the fuel filler assembly with an updated part. Since you have a 2004, I expect that your car has the same troublesome full filler. This thread contains a good discussion of the fuel filler issue. If you scroll to the end of the post, there is a pdf with instructions for replacing the fuel filler.
I appreciate that your problem may have a different cause, but this is worth checking out. Good luck solving your problem.
#11 ·
Update:-
The gas gauge wasn't working correctly so we got a new sender unit (Chinese off amazon) it sits in the fuel tank on the left side but the Chinese part didn't work correctly, so I sent that back and bought a new name brand part from Rockauto but it didn't have the pressure sensor built into the sender unit so it wasn't the correct part and that was returned to rockauto. We went to a scrap yard and found C-class car with new (certainly not original) fuel sender unit and pump, we bought both. The "new to me" pump and sender unit cured the gas gauge issue and also replaced the tank pressure sender. But we are still getting codes and a check engine light. We have now replaced almost all the emissions parts. We had previously checked the purge valve in the engine bay (see original post) and it tested Ok but we realized it was clicking a lot so we replaced it, did a drive cycle and got the car to one inconclusive and went straight to the emissions center and it passed. Then straight to get it registered in my name. What a crazy journey.
To celebrate the passing of emissions I went out and bought a VW EOS with a bad clutch (wife thinks i'm crazy) as I arrive home I find the front air suspension has collapsed on my wifes Equus, but we were heading down to Tucson in our Saturn Sky to do some autocrossing and the clutch went bad in the Sky. Oh the highs and lows of this adventure filled weekend. At least the Mercedes is back on the road.
#12 ·
Arrgh! I used to have to deal with that shit. The readiness indicators not going to complete, but not failed. Driving thousands of miles after making repair and still not clocking over. 6 months passes and still incomplete, and now they can impound the vehicle is driven on the road, but can't get it to turn over without driving it. And you can't get it out of impound unless it's registered. Arseholes.
I finally registered it at a friends house in Lake Tahoe. No smog.
I've sinced moved to the Oregon coast, and no smog is required.
