I've posted my solution for supporting the car for working underneath on other forums, but it don't believe I've posted here. Periodically we hear reports of someone working under a car supported by jack stands or worse yet just a jack.
For everything but work that requires access to suspension components e.g. brakes, bearings, ball joints, etc. I'll use cribs. Wooden cribs have been used over the years for supporting extremely heavy things, like cruise ships, houses and boats. Wood has extreme compressibility and doesn't break or shatter, but rather breaks gracefully with lots of warning.
Mine are built out of 2x4s crossed, 17x12. I glued and screwed them together and painted to ensure longevity. The top crib has a 3/4 plywood platform and 2x3 integral "chocks".
When not in use, they stack nicely out of the way.
My set is enough to go 4 high which provides plenty of operating room under the car, though I often only need 2 or 3 high to get the job done (use the minimum needed for clearance for the job at hand). One could go higher, but should modify the lower units to be wider to provide additional stability and prevent getting top heavy.
Cribs are easy to use, cheap and extremely safe. In fact they can serve as a backup for jack stands if doing suspension work.
One little trick I've used when working on the car is to get it on the cribs, then take a bit of weight off the springs by using a floor jack on either the differential or engine cross-member. This will get you an extra inch or two without compromising stability or safety. If the jack were to let loose the car would just settle back on the springs.
The only real danger of falling would be in an earthquake, but that risk would be an order of magnitude higher if using jack-stands.
I hate working under the car and feel it's important to do everything possible to reduce the risk.
People have asked whether the cribs are pinned together or otherwise secured and the answer is no. When I built them I painted them with latex paint and strangely, the cribs often still stick together so well they have to be knocked apart when it's time to re-stack them after use.
Be safe...
Be safe...
