Thought I would make finding the fuse charts a little easier for all. There are four fuse charts that cover all models of the W220 (and also the W215). They are shown below: The four charts with part numbers ending in 1500, 1600, 1700 and 1800. A fifth chart, ending in 1400, was replaced by 1500.
Also below is a chart labeled "Fuse Chart Guide" to assist in determining which applies to your particular car; you can determine the applicable chart by first finding your model and year, and then applying your VIN. In doing that you will find which of the four charts is for your car.
Please be aware that even with the correct part number the chart may not appear correct for your car as the charts are a 1 for all (Charts cover all cars worldwide left or right hand drive), so a fuse listed may or may not be installed in your car.
If you can't find the part number there are plenty here that can supply it from your VIN.
Dean
Dean
