I had an issue this weekend when doing a flush of fluid in the RST system. I removed my hardtop and when attempting to raise the soft top, the switch light blinked and nothing happened. The roll bar would go up and down just fine. I did a search here and found some pictures (I believe posted by lynns) that showed the proper position of the rear latches. Turns out one was up (driver side - unlocked position, ready to receive the top post to go down to the locked positon) and one was in the locked position (passenger side - down). Both have a switch that "tells" the controller that everything is okay. When all is good, the top will work. When the two are out of sync, the mechanisms will not work. I manually opened the tonneau cover and attempted to move the locked-down lever up with a screwdriver as others had some luck with. No luck here. I unbolted the latch (three nuts) and pulled it forward. I found that at the back side of the latch, there is a silver tab that is spring loaded. Pull and hold the tab and you can then pry up the latch-lever with a screwdriver. This same tab, when let go, will then lock the latch-lever in the correct place. So when both latches-levers are up, the switchs are closed and everything works as it should. I stowed the top and shut the tonneau cover and pushed the switch and my top came up. Now I could not tell if there was oil on the cylinder leaking or if it was from when I sprayed WD-40 onto all parts just before I checked (mental lapse). I'm not quite sure how the hardtop was released with that cylinder being in the locked down positon and I did not put the top down and up a second time to find out if it would work as I wanted the top up, it was getting toward dinner time and I wanted to jam some on my guitar some, so if my problem isn't solved, I'll report it in another post.
