Failed rebuilds, crumbling seals, plugged filters, alignment
Folks,
it's been on my to-do list for a while now to summarize and explain what happened in this convoluted case. I have had some concerns about appearing too aggressive towards my competition.
Initially, Ulflei reported about slow roof operation after just having had his mechanic rebuild three cylinders himself, about having to steer the top in the front when closing, and about the mechanic thinking the pump was weak.
Then things got worse and parts of the roof were not operating any more. It turns out that there were numerous leaking cylinders. There were actually two kinds of cylinders left in the car when Ulflei originally started this thread: those already rebuilt by our friendly competition a little over two years ago, and those that his own mechanic rebuilt recently (rebuilds of the first rebuilds).
Of the three cylinders rebuilt by his mechanic, Ulf sent in only one, because his mechanic warranted the cylinders and would have charged for the labor of removing them again. Trouble was, one of the mechanic-rebuilds was found to be leaking right away on account of scratches. It was actually the easiest one of the bunch to rebuild. Ulf reported that his mechanic replaced that one right away. We received one of the other mechanic-rebuilds, and I don't know if that happened by accident or not. In any case, it was a rear lock cylinder, the second-easiest to rebuild. It was
heavily scratched way down the shaft, as well. That one needed to be replaced.
Of the remaining cylinders rebuilt by our friendly competitor, Ulf sent in seven, which was the whole set short of the ones done by his mechanic and short of one main lift cylinder. The findings were the following:
Six of the seven
regular, molded PU seals used in those rebuilds were in different, serious stages of decay! They were actually crumbling, which caused the continued slow roof operation - I'll explain that below. The seventh seal, the seal for the main lift cylinder, wasn't seriously decaying yet, but it was losing its softness. That actually allowed for a leak along some tiny scratches in a stationary surface touching the seals, inflicted by the party of the first rebuild. Those tiny scratches were sealed as long as the regular PU seal material was soft.
The photos below show the following:
1) Rear lock cylinder with date and initials by our friendly competitor, as well as Ulf's postmark, in case anyone thinks I was making this up.
2) Tonneau lift cylinders, also having
crumbling seals
3) The seven seals in different stages of decay.
That seal material is (practically) the same as what Mercedes used in the early SLKs, and the decay pattern is similar. However, the SLK pumps are made to be less sensitive to contamination than the SL-pumps.
The interesting continuation of this case was, that even with the fixed cylinders the roof was
still lifting slowly. The individual cylinders for RST operation are activated by solenoids in the valve blocks. Every solenoid has a fine filter mesh to keep particles from compromising its function. Since the main lift cylinders have the most fluid going through them, it would stand to reason that their
solenoid's filter gets plugged first by remnants of crumbling seals. I repeatedly coached Ulf's mechanic over the phone how to pull the solenoids on the valve blocks, in order to inspect the filters. That was it! The problem of having to steer the roof in the front upon closing was resolved by
alignment, as suggested.
In defense of Ulf's mechanic, he is actually a smart and enterprising guy. The scratches on his own rebuilds were made by his employee, and plugged solenoid filters are pretty rare.
Moral of the story (for those who managed to read this far): send your cylinders to us for rebuild and upgrade. Our seals are chemically much more stable than those of our friendly competition, and much more stable than the OEM seals. We have special tools for every step of the way, and we will give you support by email or phone if there are more problems with your system. I am not one who enjoys boasting about my own products, and I was very hesitant to even reference my competition in this post because I don't want to invite negativism here - note the time lag between the event and this summary. However, the problems that Ulf encountered, and similar problems that others have had, were so serious that I thought this kind of clarification would be justified and worthwhile. I apologize to anyone who is now feeling badly about what is in their system, and have the encouraging words that many of the rebuilds from our competition that we get as parts of complete sets or as core returns, are still in good shape. I would still put Dennis' seals on the same level as the OEM's, so nothing was really lost compared to buying new cylinders for those who decided to have him rebuild their cylinders. This particular case was rather extreme, and the same might have happened with OEM replacements. Dennis has served this community well, and he is not a fast-talking salesman like some of the other "rebuilders" cropping up (and disappearing again) from time to time...
I hope that all will be well now for Ulf's RST for a long time...
-Klaus
klaus@tophydraulicsinc.com
