W210 sunroof cover grills instal
1 reading
6.3K views 9 replies 5 participants last post by  raymond-
Can anyone give me some advise as to how to install the new grills in the sunroof cover??? I got the new ones and they are not as sunbaked and brittle as the ones I had on the car (only one actually) but it seems that I need to flex them quite a bit to fit in and I would hate to break them. Any ideas how to do it? Heat?
2682638
This should assist you in getting access.
More general info here as you scroll thru:
#6 ·
Suggestion: use the SEARCH feature for this forum. others have commented on their challenges
in the past so I hope tips and solutions have since been incorporated to their threads.
#7 ·
Thank you for the tip. I tried that prior to posting this. There is a lot of posts about the sun cover vents, but I have not seen anything about INSTALLING them, except one that does not really give a lot of info.
#9 ·
I had my sunshade recovered nicely local upholstery shop for $35.
Ill be darned if I can recall what we did.
I think mine were good to keep & he carefully tucked edge of new cover under each vent.
That was 2 years ago. I read most of those posts & recall that breakage was a concern.....but not sure if theres a satisfying fix or upgrade.
Perhaps a suitable replacement material affixed from side facing up ?
#10 ·
i'll keep digging through my notes. I was pretty certain I had some removal/install tips on the vents. I should say the last I recall seeing them was over 10 yrs back though. crossing fingers...
