Just couldn't remember where I saw that: - - Now "Search this Thread" ^^^ or "Control F" - - Click the primary hyperlink above highlighted search item - good to go.
Mercedes Benz Model 124 - M103 Maintenance Manuals
................................................................. 4MATIC ... 4MATIC
260E ..........300CE ....... 300E ........ 300TE ...... 300E ....... 300TE
1987-92 ... 1988-89 ... 1986-92 ... 1988-89 ... 1990-93 ... 1990-93
124.026 ... 124.050 .... 124.030 ... 124.090 ... 124.230 ... 103.985
2.6 Liter .... 3 Liter ...... 3 Liter ...... 3 Liter ...... 3 Liter ...... 3 Liter
Service Introduction - Model Year 1992, Model 124 (USA)
00 - Maintenance Procedures, Identification and Owner's Manuals
General, technical data
00-005 - Instructions for use of Service Manual
00-010 - Engine and Vehicle Identification
00-015 - Vehicle Identification Number Locations
Maintenance Sheets
1981 Model Year Maintenance Sheet
1982 Model Year Maintenance Sheet
1983 Model Year Maintenance Sheet
1984-1985 Model Year Maintenance Sheet
1986-1997 Model Year Maintenance Sheet
Maintenance Jobs
00 Maintenance Jobs - 1981 through 1993
Intro - Maintenance Manual Model Year 1981 to 1993
0050 - Inspecting component condition
0051 - Inspecting condition of lines and hoses
0053 - Inspecting components, lines and hoses
0090 - Suspension and body structure inspection
0091 - Water leakage and corrosion inspection
0101 - Engine oil and filter change
0560 - Adjusting valve clearance - M110, OM616, OM617
0561 - Checking valve clearance - M102.983
0750 - Checking and adjusting idle speed - OM601
0758 - Checking and adjusting idle speed - M110
0760 - Checking injection timing - (diesel)
0761 - Adjusting injection timing - (diesel)
0780 - Replacing fuel filter
0781 - Replacing fuel prefilter - (diesel)
0932 - Cleaning metal-reinforced air filter element - (diesel)
0980 - Replacing air filter element
0981 - Replacing air filter elements - M116, M117
1350 - Checking condition and tension of V-belts
1351 - Inspecting poly-V-belt
1470 - Checking intake/exhaust manifold seating - OM616, OM617
1480 - Replacing oxygen sensor
1550 - Check spark plugs, replace if necessary
1580 - Replacing spark plugs
2010 - Checking coolant level/antifreeze protection
2011 - Checking coolant level
2050 - Checking cooling and heating system
2080 - Replacing coolant
2290 - Adjust engine stop, retorque engine mount bolts - OM616, OM617
2291 - Adjust engine stop - OM616, OM617
2551 - Checking clutch disk for wear
2601 - Manual transmission oil change
2610 - Manual transmission, checking, correcting oil level
2702 - Automatic transmission fluid and filter change
2710 - Automatic transmission, checking, correcting fluid level
2801 - Transfer case fluid change
2810 - Transfer case, checking, correcting fluid level
2910 - Clutch system, checking, correcting fluid level
2950 - Clutch system, inspect
3022 - Inspecting, lubricating throttle linkage
3052 - Checking and adjusting idle speed adjuster - OM616, OM617
3211 - Level control, ADS, ASD, 4MATIC, fluid level
3251 - Inspecting self-leveling suspension
3310 - Front axle, checking, correcting oil level
3353 - Checking front axle ball joints
3355 - Checking ball joints using special tool
3501 - Rear axle oil change
3510 - Rear axle, checking, correcting oil level
3565 - Rear axle mount, adjusting limiting stop
4050 - Inspecting/rotating wheels
4051 - Checking tires
4060 - Correcting tire pressure
4070 - Tightening wheel bolts
4152 - Inspecting drive shaft flexible coupling
4210 - Checking brake fluid level
4250 - Inspecting brake lines for damage
4251 - Checking brake pad/disk thickness
4252 - Inspecting, cleaning brake disks
4256 - Inspecting parking brake cable
4261 - Adjusting parking brake
4280 - Replacing brake fluid
4290 - Brake test, parking brake check
4611 - Checking power steering fluid level
4650 - Checking steering play
4671 - Retightening steering bolts
4750 - Checking fuel system condition
4970 - Retightening exhaust flange
4971 - Retightening exhaust system connections
5410 - Checking and correcting battery fluid level
5451 - Checking warning and indicator lamps
6030 - Cleaning water drains
6190 - Removing and installing engine compartment lower panel
7220 - Lubricating door hinges
7221 - Lubricating door locks
7710 - Hydraulic top, checking and correcting fluid level
7730 - Sun roof, clean and grease rails
7750 - Soft top, checking locking tabs
8210 - Checking, correcting windshield washer fluid level
8230 - Cleaning cassette deck tone head
8231 - Cleaning antenna mast
8251 - Headlamp and exterior lamp inspection
8252 - Windshield and headlamp wiper/washer inspection
8280 - Replacing windshield wiper blade
8312 - Checking, correcting A/C refrigerant charge
8381 - Replacing dust filter for heating/ventilation
8382 - Replacing active charcoal filter
8383 - Replacing recirculating air filter
8820 - Lubricating folding side mirror
8821 - Lubricating hood
9150 - Inspecting safety belts for damage
9151 - Backrest lock - check operation
9490 - Removing and installing lower noise encapsulation panels
9850 - Checking body for paint damage
00 Maintenance Jobs - 1994 through 1997
Intro - Maintenance Manual Starting Model Year 1994 - - - Select page...
0780.1 - Replacing fuel filter (Diesel engines)
0780.4 - Replacing fuel filter (M104, M119, M119 with LH-SFI)
0780.5 - Replacing fuel filter (M104, M119 with HFM-SFI)
3211 - Level control, ADS, ASD fluid level
4051 - Inspecting tires
AP83_00-8381 - Replacing dust filter for heater/ventilation
8384 - Replacing activated charcoal prefilter
Service Information
00/57A - Revised checking/correcting oil level procedure
00/139 - Lubricating hood latches and hinges
83/83 - Conversion of R12 to environmentally friendly R134a
Service Intro - Model Year 1992, Model 124 (USA), Introduction into Service
Service Intro - Model Year 1992, 400E/500E, Introduction into Service
Owner's Manual
Owner's Manual, 1994 E320 (Estate)
Owner's Manual, 1995 E320 E420 (Saloon, Coupe)
Owner's Manual, 1995 E320 (Cabriolet Supplement)
Miscellaneous
Misc Reference Articles
Mercedes U.S. Models
Maintenance Sheets
Maintenance Jobs
Service Information
Owner's Manual
Miscellaneous
