Lately my 1992 500SL in 92 degree weather here in Ct. is getting hotter over 100 degrees while idling with the AC on. I have just replaced the thermostat and I'm planning at a later day to replace the radiator and water pump. I have checked my fan clutch by driving for a while with the AC on and stopping the car with engine off, I can spin my fan blade and notice that it has the same forced when cold. I understand that when engine is hot, the fan should not move with your fingers as when trying to rotate it. I'm assuming my fan clutch is not functioning like it should. Here's my problem or question, as by searching I've found that your have 3 options on the type of fan clutch to buy. The "Standard", "Heavy", or "Severe" fan clutch. Being my car has almost 300,000 miles now, what would be a practicable choice ?. Also, I have not found a source for a "Heavy" or Severe" clutch type for the 92 SL just the "Standard" type. Attached is one of the articles I have found concerning fan clutches types.
FAQ - Fan Clutches.
Thanks in advance...
FAQ - Fan Clutches.
