(Video) Replacing Mercedes S550 (W221) Front brake Rotors and Pads
3K views 4 replies 4 participants last post by  Mean2007
I replaced front brake disks and pads 2 years ago, but recently I feel vibration while high speed and uneven brake power while low speed. So I decided to replace them again with different brand.
Here is the video link:
This is really well done, thanks for sharing! A lifelong engineer I'm always looking at ways to do things better so hope this sounds constructive. :)
I would get jack stands more suited for the objective. For ~$100 you can have a pair of Esco stands that work well with our Mercedes jacking points. Prior to having a lift in my garage I used this with a floor jack like yours;
Esco 3 ton jack stands
I almost had a spasm when I saw you jacking under the front of the car, then I remembered that you have a 4MATIC. Another board buddy asked for tightening torques so I thought to share them on this thread as well.
  • Locking bolt, brake disk of front axle to wheel hub 10Nm
  • Self-locking bolt, front brake caliper support to steering knuckle 180Nm
  • Self-locking bolt, rear brake caliper support to steering knuckle 110Nm
  • Bleed screw to brake caliper 14Nm
  • Wheel bolts 150Nm
Much respect for you ending the video by cleaning your tools and putting them away!
