Mea Culpa...
43sqd,
Please accept my most sincere apologies for not having returned the favor of your reply. To answer your earlier questions, I changed the injectors because it seemed to be (at least to me) the only thing that the cylinders had in common. For example, I am a metaphysician, so I attempted to use deductive reasoning (which you can not use on an ML320) to determine a diagnosis and therefore formulate a treatment. Out of all the symptoms, the only thing left were the injectors. Seemed logical to me... and it did seem to work. I allegedly sealed the leak with a little gasket maker/sealer around the intake. I actually took this off last night and replaced the tube with a new one and the gasket to fit. It does seem to be a little "loose" however, but I have put it on as tightly as I could.
With regard to the EGR valve, I did some research after my post and found my error. It still seems weird to have this little thing just hanging off there, but, oh well.
Yesterday, I had the muffler and catalytic converters inspected by a muffler shop. He said that all were well, and the noisy muffler was due to the engine running "like crap". I swear there is a leak somewhere, but I just can't find it. Sometimes it runs great, other times it will sputter and backfire upon takeoff. I just don't know. The fact that the codes are so ambiguous only frustrates me more. Yes, I know that there is a random misfire and that cyls. 5 and 6 are misfiring- BUT WHY?!
Perhaps it is a leak in the plenum? I could just choke the thing.
