I have been on the hunt for a square body and a lot of the listings don't give you a list of the options it came with from the factory. Is there anyway to "decode" the vin to get a list of the options the mog came with from the factory?
Thanks! Yeah I have been looking for a mog for a couple months now and haven't had much luck here in the USA. There are tons of them overseas and most the listings are vague so I was hoping decoding the vin might help.The VIN is able to be linked back to the specific truck's data card on file (in theory) which could tell you how that specific truck was built. But... as with all things unimog, nothing is given, so you card may or may not still be on file. The mil-spec and big utility project builds were typically all built "the same" with only very minor variations so one "may" be just as good as another.
You cannot however just drop the vin into a web page and get an SA code dump... generally. sketchy russian pages claim they can. Your local MB dealer probably not. When I worked dealer we had a dinosaur computer that housed all the older vehicle data and magically had an entire MB Trac and MB Bus database, even the L trucks... but no unimog.
Scott at Expedition Imports can generally be very helpful with this process. Others on the board have some vestigial access to builds as well, Trevor comes to mind right off.
What options are you looking for in general? If this just a comparison tool, cost for value judgements etc?
I own a small construction business and it seems like concrete trucks, utility trucks and delivery trucks are always getting stuck, sometimes pretty bad. My plan is to set the mog up with a couple nice winches so I can pull whatever is stuck out. Being able to drive the truck to the site instead of hooking up a truck, trailer and loading a machine to pull someone out. I have been looking for a heavy duty (ten lug wheels) so that when I add larger tires, winches etc. the mog can handle it. Its not something I will be taking down the highway on a daily basis. I appreciate your help as I am constantly learning something about the unimog.Horsepower and braking power should be considered when looking at large tires. U1300L Owners have mentioned degraded braking performance after going to the 395 XZL's, and getting them rolling up to speed also takes some effort. As mentioned, they will grab parts of the chassis at full lock, or approaching full lock.
There is a reason that there are 'Big Square Cabs', and 'Little Square Cabs'.
It all depends what you are doing with the truck. if you are just doing low-speed 'wheeling' with the UNIMOG, then tire compromises might not be as detrimental compared to a rig that you intend to drive on the highway a few hundred miles before you get to the 'wheeling' part.
Still, you'd never want tires that the brakes struggle to have full control over. 'Stops on a dime', vs 'Stops on a buck two fifty'...and lurches a bit while it is doing it.
Not mine and I know nothing about it except that it has a large midmounted winch.I have been on the hunt for a square body...
Yes they do. The spare on the front looks much taller than the ones on the mog.These look pretty big:
