Hey guys, my new (to me) 02 g500 gave me an acceleration problem the other day. It took about 1 minute to make it to 45mph. It didn't throw any fault codes or give me any other problems for a 300 mile interstate ride home. Upon arrival, at slow speeds it did it again and threw a Throttle Position Sensor code... Then a window fell.
I went to the local dealership today to order a tps and have them install a bad window regulator. After about an hour and 800 dollars, they informed me that I have a transmission problem. I told them I already knew about the TPS and I would be installing it myself. The service manager insisted I had a trans problem that was unrelated. Knowing that dealers are pretty unfamiliar with this car, I didnt argue and I told them I would get back to them after I installed the sensor and let them know.
Then, on my ride home I went to get on the longest bridge in the world (25 miles with no shoulder in rush hour traffic)- lake pontchartrain causeway. The G accelerated to 25 mph and refused to up shift... It was turning 5k rpms just to move slowly. I tried knocking it up a gear and it refused. I tried turning it off in neutral, then back on, then shifting in D.. still wouldnt shift. After 5 miles, I made it to the crossover and parked it. I let the tranny cool for 10 minutes and turned the other way (no traffic) to get back to the main land. As soon as I did this, it drove fine. I made another U turn and came home with no issues.
HELP!!?!?!??! Could the TPS be causing the car to go from under revving to over reving? Why the heck wouldnt it shift gears automatic or manually?
I'm going to call the stealership and give more credit to the transmission claim and see what they think is wrong. I know he said it was some rings and seals but nothing mechanical. 500 in parts and 300 in labor.. The TPS is definetely faulty too.
