What are the torque specs for valve cover gaskets on a s500 and do u use silicone on covers?
I have a 2001 SL500 is the same torque for the valve cover?Your S500 uses the M113 engine. Valve cover torque is 8 Nm.
You should also check to see if the breather covers need to be resealed (very likely), and in any case, replace the breather hoses.
DIY for all of this on the M113
http://www.benzworld.org/forums/w22...w220-s-class/1927017-valve-cover-gasket-breather-cover-sealant.html#post7946465
