The “R” Button?
1 reading
33K views 13 replies 7 participants last post by  victorvictor
Hi everyone, where is the “R” button located in my 2007 SL550? When I use the buttons on the steering wheels to scroll through menu’s… it says press “R” to get tire pressure readings. I don’t see any R buttons anywhere or am I this blind???
#5 ·
Wait, I have a 2007 SL550 and I was dismayed that I couldn't get actual tire pressure readings on the dash like i can in my 2008 S550 S-Class. You mean to say that is CAN be done? I am going to try it! It is kinda cool to see actual real time tire pressures as you're rolling down the hiway.
#8 ·
It's my belief that even if you don't use the system to see the actual tire pressure, the system will light up that little orange picture of a tire, if and when any of the tires gets to a pressure that's outside of the accepted normal range, thereby alerting you about a problem. But being able to view individual pressures, allows you to determine which tire is having the bad day. Soon as I drive my SL I will report back on this.
#10 ·
You have the "low-line" TPMS which does not display the pressure from each individual tire. Instead, it just sets a baseline for all tires when you reset it. When the pressure goes too far off that baseline, you get an alert, but it won't tell you which tire. The "high-line" TPMS can tell you the exact pressure reading for each tire. AFAIK, there is not an easy way to upgrade from the low-line to the high-line system.
