Sprinter 2.1 aux ac stretch belt HELP!
1 reading
8.4K views 6 replies 4 participants last post by  dharmasprint
HI all. I am an automotive tech in toronto. I work on a fleet of sprinters and half the fleet have the 2.1l diesel motor. All have the aux AC system mounted to the roof. On the aux AC compressor there is a stretch belt. Does anybody have a line on a tool for installing the stretch belt. The belt has to go around 3 pulleys all together and there is only 4 small torx bolt in the crank pulley to turn it. I have the universal belt tools and they get the belt on the crank and AC compressor but it is quite the job to get the belt over the 3rd idler pulley. i have destroyed a couple belts trying to get them on. Every time i get one i think that there must be a better way.
When I ran into this problem, I found the attached information regarding the tools necessary and then I purchased them directly from the dealer (unable to locate anywhere else @ the time). The assembly tool 651 589 01 43 00 is the necessary tool to stretch the belt for removal / installation of the idler pulley. 651 589 05 63 00 also was helpful, but on the 2016 model I haven't had any success with the counterholder tool that is supposed to help with rotation of the crank pulley because it doesn't seem to reach deep enough to grab onto the head of the crank pulley bolts.
#4 ·
I bought the whole set and still ended up making my own countersunk crank tool bent from the straight one in the toolset using an inductive bolt remover vice fire-wrench. You absolutely need the idler pulley install tool once the belt is (finally) on. It also took a couple of tries to get the right belt, which is necessary too...
