SLK55 AMG (R171) vs SLK32 AMG (R170)
14K views 33 replies 11 participants last post by  mattslk32amg
Clem - 3/14/2006 1:12 AM
the interior has that rubbery feel, but I have a feeling it will age better then the old SLK's interior, especially the center console. The rubber material is quite thick, so no paint peeling problems should occur.
Peeling was a problem in my '98 230. The problem is resolved in the 2003 32. There is no peeling issue at all. Mercedes dispensed with that thin rubber layer which was the cause of the trouble. I just think that the softness of the 55 rubber interior renders it prone to damage. In fact the one I drove with only 1800 miles already had some damage.
This is not true. I have a 2003 SLK32 and have had a peeling issue with the center console. It may not be as bad as the older cars but it is not immune to the problem.
Clem - 3/14/2006 7:29 AM
Really? When my 230 peeled they centre console was replaced with one that has no coating at all. I mean nothing - just plastic. I have the same in my 32. You can take anything you like to it and there's just nothing to peel. The glove compartment lid looks as though it may still have a coating though. Maybe your centre console is a different spec to mine? Don't know. If yours is peeling, maybe you should look at getting it repla$ced with the later type of centre console. Must say I was pretty annoyed that Merc refused to carry the cost of replacing it though.
I have had the center console replaced under warranty. The material on the new console appears to be the same as on the old console.
