Hi and Good day to you all.
I am a new member and have two problems which I need help with. One I believe will be relatively simple for you folk and the other may not be.
Parking/Side Light.
Our A150 is Right hand drive and we have a problem with the Front Drivers side Parking/Side light. When using the selector switch on the dash, all of the side lights function with the exception of the drivers side front.
The headlight assembly contains three bulbs each. Two H7 Head and Full beam and one other for the parking light
When I try to put the lights on using the Parking light function, both passenger parking lights function
When I try to put the lights on for the drivers side, only the rear light functions.
I have replaced the bulb in the front and this has no effect.
I cannot see any warning lights on the instrument panel.
Can anyone tell me if the front and rear drivers side parking lights have a common supply from the switch or have any suggestions as to the most likely cause of the fault.
I will ask for assistance with the other fault under a separate post.
Thanks in Advance.
Parking/Side Light.
Thanks in Advance.
