RESTORATION MERCEDES 220 W187 1952
34K views 48 replies 15 participants last post by  compconsult
Hello everyone
I am writing from Spain and I am new to this forum .... my passion is classic cars and am currently restoring a Mercedes 220 W 187 of 1,952.
If I make a spelling mistake, I apologize because my English is not too good and helped me a translator to write this post.
Then I put a few pictures of the car ...
As you can see, the car is totally "new" and just need to take a little dust ...:(
Gradually I'll sending photos of the restoration ...
Hope you like
a greeting
#5 ·
Do not worry interject, I figure I only have about 3,000 hours of work to finish ....
Regarding the question of Scottejupiter, the car remained on the street for 40 years ...
Then I put some pictures of the parts that have been dismantled ...
#9 ·
You're not alone in tackling such a project. I'm in the middle of the same thing on a 1951 170S, I've got some rear-end damage to deal with though :(
That's the worst of it, but it'll take some work to reshape that rear and repair the trunk floor. Everything else is solid.
#10 ·
Hello again
cooljay, baybear Thanks much for your comments and support VaiFanatic in your work.Congratulations on your 170
Following the restoration, now it is the turn to remove the chassis from the body, unfortunately, have not yet given me my new shop and I had to do it using a forklift .... but it has been fun.
There are some pictures ...
a greeting...I will continue to report...
P.D. forgive the quality of the photos, but they are made with the phone
#11 ·
Hello again
Following the restoration, now it is the turn to remove the chassis from the body, unfortunately, have not yet given me my new workshop and I had to do it using a forklift .... but it has been fun.
#14 ·
Once the unarmed body, I lifted the head to see what state the cylinders and pistons were ...
This has been very hard work, as I was totally glued to the engine and I had to use the crane to lift ...
After I've completely separated the engine from the chassis ....
As you can see in the photos, their status is quite unfortunate.
#16 ·
Gran Proyecto
1952 - 6 cylinder overhead cam
can the block be reused?
How is the head, can the valves be removed?
crankshaft usable?
What is your goal, return it to original stock condition?
Enjoy the body lines of this car!
What a project
Please continue with the great pictures
Me gusta mucho
Buena suerte con este proyecto
:nerd
#17 ·
Thank you Matvh for your answer...
Unfortunately, my English is not very good and I have to help me with the translator to speak to you, which makes many nuances of the things I want to tell you is lost. I apologize for that.
I answer your question, I say yes, I think leaving it in its original condition except for the paint and upholstery, I think I'll change, but for now it is too early to decide.
Another question I asked was whether Matvh could use this engine and yes, I can use it.
The only serious problem that despite its appearance, is a piston that is stuck, but I've gotten out, apart from this, the side engine covers have some corrosion .Another thing I'll do is change the rings , for everything else, I think I can restore it in its entirety.
Here I put some more pictures of the condition of the engine and the gear box ...
#20 ·
Amazing work! I cannot wait for the next set of posts. Keep up the great work
#21 ·
Mas Preguntas / More Questions
Are the Pistons original?
Will you have to bore the block? 30 / 60 thousands over?
Does the block / crank need to be aligned bored?
How do you obtain data on rebuilding this engine, specifications? a manual?
Are parts for this engine available?
What a puzzle to put back together
This is a post World War ll car, were many of these built?
To put the car back to original will be a true challenge
The car seems to be all together, but in rough condition
Mucho Mojo!
#22 ·
Thank you very much for your interest ... Matvh answering your questions, I'll tell you that these are the original car pistons, and coming out in the last photo IS NOT NEW, but one of the original restored by me.
The rest of the car similarly think restore because it is a great challenge for me to go one by one recovering parts.
Regarding technical data, this is not new for me as I have previously restored several Mercedes (1.958 300 D "Adenauer" W 189), (1.955 300 "Adenauer" W 186 cabrio ) (1.953 300 SC W188), (1,958 190 SL W121) and 1.964 W113 230 SL "pagode" ) .For this reason, I have all the necessary documentation.
As for the production of 220 W 187, here I put some data.
Mercedes-Benz W187 is an automobile produced by Which was Mercedes-Benz from 1951 to 1955 Introduced at the Frankfurt Motor Show in April 1951 as a six-cylinder luxury car, it was sold in sedan, coupe, and cabriolet body styles, all With the 220 ​​model name. Over six decades several very different models Have Been branded as a "Mercedes-Benz 220 of" which is why the 1951 car is now Usually Identified internal ITS works using number as the Mercedes-Benz W187.
production 1951-1955
built 18,514
Saloon: 16,154
Cabr. A: 1,278
Cabr. B: 997
Coupé: 85
This car marked a new era, as it was the first six-cylinder Mercedes built after the Second World War and is a transition between the 170 (which takes its body) and 300 "Adenauer", from which it takes its front, being the first post-war car that already has the headlights recessed into the front fenders, unlike previous models (170) that even carry over fender (typical design before the war).
Well, since returning to the restoration, and as I think about seeing the parts before and after, I made an aesthetic test the upper engine cover and a wood trim door, so that you may appreciate how much work patiently and parts "resurrect"
BEFORE/AFTER
