Power Steering Pump noise fixed
101K views 35 replies 14 participants last post by  khomer2
Valvoline makes a synthetic blend power steering fluid that's just as good. I've been running it in the 2002 ML320 since I replaced the reservoir. As for the noise, it's there because of the air or lack of fluid, not necessarily because of the fluid you used. If you would've parked your vehicle on a steep incline and let idle a few minutes, then turn your steering wheel all the way to the left, then to the right several times, you would have eliminated the air. You didn't make a mistake turning your steering wheel. The mistake was not parking your vehicle on an incline. This procedure has worked very well with both my ML's.
Save
You have insufficient privileges to reply here.
