I’ve been looking all over for an answer to my problem. I probably should have just got a used pump with pulley on ebay and called it a day but I bought a reconditioned one that came without the pulley so now I need to find a pulley or take my old one off and reuse that.
I’ve been trying to take the old one off without success so any tips would be appreciated. I’m thinking it’s because I need a puller but all the ones I see say “good on most domestic vehicles” so fords and gm and the lot. Here’s one that got good reviews but I’m not sure it will work with my old pulley:
OEMTOOLS 27031 Power Steering Pulley Puller and Installer Kit, Removes and Installs Power Steering Pump Pulleys on Most Domestic Vehicles, Ford, GM, VW https://www.amazon.com/dp/B0014WH9S...0014WH9SY/ref=cm_sw_r_cp_api_glt_fabc_0VD27XP2Y9GSX6XY3YJX?_encoding=UTF8&psc=1
I tried to just find a pulley and I see only one for $200 that I know will work and then a bunch again that say fit chevys for like $30. I tried to measure the shaft and i’m getting 5/8 inch at threads and 6/8 inch at top of taper... tons of pulleys out there say 5/8 inch but i’m not sure if that’s where the threads are or at the top of taper so again I have no idea if they will fit.
You can see i’m hopelessly lost. Anyone have some guidance to help solve my pulley dilemma?
