2002 c240 Does anyone know the location of the fuel tank pressure sensor? think it may just be above back passenger wheel near tank after small research.
I’ve been tackling down problems on my car one by one and the last codes my car reads are evap codes
(Low input/circuit). I changed An Evap Pressure Sensor as it said specifically after reading codes & it ended up turning off check engine light by itself but came back after 2days. Will try to change ftp sensor which comes up as 2nd solution.
