Here's some photos that might be of interest if you are doing a winch bumper and want to put the oil cooler somewhere else. I know Ewalberg was interested to see this.
Merc sells brackets to relocate the tranny oil cooler to the skid plate (because that's where it is in the G55). If you look at the photo you can see how that works.
I found that this worked OK until I started towing a trailer, at which point things started to run a bit hot. There isn't a whole lot of breeze on the skid plate.
My solution was to ditch my custom winch bumper and buy an ORC one (got it from Kerr). The ORC one lets you put an oil cooler below the winch, where it gets some air (not as much as the stock bumper, but more than you get on the skidplate).
Just to make sure I got the temps down as much as possible, I put two oil coolers in series - one in the ORC bumper, and one on the skid plate. Both are the stock cooler. I did a trip to Baja this week, and it runs a lot cooler than just one cooler on its own. I checked regularly with an infrared thermometer.
Anyway, take your pick: up front, or on the skid plate, or both.
By the way, if anyone is interested in the custom winch bumper that i'm not using, let me know. I don't recommend it if you are towing, but if you aren't, or you have an older G without the bumper oil cooler, it would be fine. I posted some pictures already, if you search for my postings. I'll let it go real cheap.
