Hello!
I am slowly gaining knowledge about swapping my 2.0D OM601 for 2.5TD OM605 with mechanical pump.
There is however one big issue I have: conversion of 2.5TD to mechanical pump. I know I can use the OM602 mechanical injection pump but the question is what pump I need. I know there are two things I need to know about: ALDA and ELR. I see that there are also manual transmission and automatic transmission versions of injection pumps, I don't know why. I simply don't know which injection pump I should choose for that engine.
So, for what I know is that ELR is the thing that increases idle RPM on cold and AC enabled. From what I see, If my car does not use ELR so it means that I should get an injection pump without ELR. Also, because OM605 will have a turbo, I need ALDA for smoke limiting.
From what I understand, ALDA is basically a cylindrical thing at the top of the IP:
And ELR is a two-pin thing behind the IP, so non-ELR pump will have something like this for the vacuum tube:
Unfortunately, from what I see, the 2,5TD in W201 and W124 had a IP that had ALDA but also had ELR:
So it seems that OM602 2,5TD pump will not fit my vehicle.
BUT
It seems that on online parts catalogs the W124 2,5D (no turbo) had this pump from the image below:
It looks like it does not have ELR and have ALDA. Now the first question, is it really ALDA? If yes, why is it there on non turbo engine? What is more interesting, I have the same cylindrical thing on my OM601 2.0D injection pump.
Now, the "???" thing. What exactly is it? For example here is the injection pump from automatic transmission car version which does not have that part:
So, what exactly should I look for? Is the cylindrical thing always the ALDA even in non-turbo versions? Also, does OM605 have a thermo-valve for non-ELR idle control?
Thanks!
BUT
Thanks!
