i spent nearly 2 hours today working on my oil change.... i change my own oil for many other cars but today i learned the e350 is just not a pleasant oil change experience.
First of all, the car is so low off the ground (sport package) that removing the bolts for the undertray takes more effort and contortions even with the car jacked on one side. Then once removed i had trouble locating the drain plug, absolutely confused locating at first that i also ended pulling out the front skid (protection plate).
Finally once located the drain plug, i concluded that the location/orientation of the plug wont allow as much oil to discharge so i decided to put things back, taking another 30 mins as getting the screws aligned for the engine tray was not simple as the last few were tough.
Now I know why there are so many posts of topside draining vs. Bottom plug drain..... I wondered and now i know. TOPSIDE all the way!!
Posting this note for comments on my own self incompetence but also to warn other newbies. FYI, i service all my other cars for oil, trans, brakes, etc. Never really touched this E350 until today after warranty expired .. Actually replaced air filter with K&N and filled washer fluids just fine.
