Normally, I do my own brake jobs - pads and rotors. Two years ago I replaced the front and rear pads on my 2002 ML320 (now, with 170k miles). Afterwards, I noticed the brake pedal was soft. It would stop the ML with no problem, but now the pedal would almost go to the floor. I check the brake fluid level and even bled the brakes, but the pedal was the same. Again, the ML would stop easily, but the pedal would be "soft" or "lots of pedal", but stop the ML safely.
Fast forward to today - I put the ML in shop with my local MB mechanic (not a dealer mechanic) to have new pads and rotors. When he took if for a tesk drive and felt the soft pedal, he called me and told me that the Master Cylinder needed replacing.
He replaced the Master Cylinder and the soft pedal persists. So, he called me and said it needed a Brake Booster.
He replaced the Brake Booster and the soft pedal persists.
I just got off the phone with him and he says he doesn't know what is wrong with the brakes or brake pedal but is going to troubleshoot some more.
Anybody have any ideas on what might be causing so much play in the Brake Pedal? Any advice "In General"? Thanks!
-Brian
-Brian
