For those of you who were part of the "Permanently locked out URGENT HELP REQUIRED" thread, I found out why my fuel lines kept getting air in. The O-ring behind the fuel shut-off valve was square and leaking. After replacing the that and the valve with one from storage, I now have another challenge that is preventing the car from running.
Is the metal pointy bit the live feed for the Fuel Shut-Off Valve? My valve is closed and and won't let fuel through. No 12 volts at this point.
No Fuel getting through to the central line.
I've not had this problem before but the valve has been in storage and I had to fit it yesterday. Perhaps it's a bit sticky? The fuse for the pump is okay number 6 under rear seats. However I cannot find a fuse for the shut-off valve.
Does it only operate briefly when the engine requires stopping? Is it shut when energised or closed? I've not observed the feed being closed before. I think it is stuck shut.
Any help would be most appreciated
Chris
Chris
