I filled up my tank with gas however the fuel gauge stayed on empty and has remained this way for the past 3 days. Does anyone have any suggestions?
Thanks.
Thanks.
Just pull fuse #5(Instrument cluster) on the fuse panel on the interior front passenger side then put the fuse back in. Make sure there is less than 1/2 a tank of gas when you do this or it won't calibrate properly. I encountered this problem after I filled up in South Carolina. As it turns out they use a much higher ethanol content than my area.Filled my car up today and all of a sudden the gas tank reads empty, so if I disconnect the sending unit it will reboot the system? Maybe I should replace the sending unit? Have you guys had success with this procedure, is this a common problem for this model?
