mixing petrol with engine oil
Hello,
So first of i have a C Class model C 180 CGI W204 - 2010, and i had this problem last year and here is what i did:
1. Took it to a MB dealer (
Vse va?e priljubljene znamke na enem mestu | Avtohi?a ?epin ) and they said this is nothing and due to making short trips (15 km to work and then back so ~35 km a day) it probably just some condensation in the engine. They changed the oil and oil filter and said i should drive it on longer trips. They also said there is no way that petrol is mixing with engine oil. After two days it was back to white smoke and more oil in the engine than max on oil dipstick.
2. Took it to a friend to change spark plugs as we thought this could be the problem and again change the oil. This did not fix it.
3. Took it to MB dealer in Ljubljana (
Autocommerce - Mercedes-BenzAutocommerce) they did a diagnostic on the car and told me that the high pressure fuel pump is the problem. They wanted to charge me 1700€ to change it. I did a little research on the internet and ordered a high pressure fuel pump from
Welcome to the online shop of the genuine car parts pro’s (Benzin pumpe for Mercedes C 180 CGI BlueEfficiency - 2010 Nr: A2710703501) Then took it to a local dealer and they changed it, so the car was running fine and i was relieved that i solved the problem.
4. This winter i noticed that the car was acting funny, so today i checked the oil and guess what again the white stuff on oil cap and more than max on oil dipstick and a strong smell of petrol.
I also noticed that the cooling liquid was low.
Any suggestions what is the main problem for this, i think it has to do with winter and the cold, because the car was fine the whole summer.
Tanks in advance for any suggestions you guys may have.
